Old 06-01-2017, 07:17 PM
FrankR105 FrankR105 is offline
Cobra Make, Engine: Lone Star, Ford 302W
Late to the party, but maybe someone could use it in the future.
Only have a one car garage, needed to remove body off the chassis, built a movable wooden frame on wheels, lifted body up to it, was then able to roll body/frame out of garage at will for access to everything else underneath (didn't work when there was snow on the ground outside!). The body work and paint was done before I got the kit, so protecting all that while doing all this was quite a challenge! The covering is thick soft-foam shelving paper (could only find it at Wal-Mart), note the pillows and blankets used for cushioning protection from the wooden frame. Also used cheap pillows between the contacts points and the body to spread out the load. Mission was successful.
