Old 06-10-2017, 07:16 PM
saltshaker saltshaker is offline
Cobra Make, Engine: Contemporary Cobra
Default Few questions
You say you are bottoming out...do you have a pan hard bar? If yes you need to remove that. Next is the front of the pinion hitting the cross member above it?
If it is the I would measure your wheel base if it is shorter then 90" it will hit. Do you have adjustable lower control arms?
Jon
The Impossible Only Takes A Little Longer
