Old 06-11-2017, 12:27 PM
MKS427's Avatar
MKS427 MKS427 is offline
Cobra Make, Engine: FFR MkIV 427
Originally Posted by saltshaker View Post
You say you are bottoming out...do you have a pan hard bar? If yes you need to remove that. Next is the front of the pinion hitting the cross member above it?
If it is the I would measure your wheel base if it is shorter then 90" it will hit. Do you have adjustable lower control arms?
Jon
If you have a pan hard bar, DO NOT remove it. Major damage and or severe injury could occur. It is an essential part of the suspension that keeps the rear axle centered under the car.
