Originally Posted by 520SC
I'm just curious, and I hope someone can answer my question. The picture below shows an OEM Ford 460 engine timing cover. There are no openings from the water pump outlet to the engine internals (except for the water inlet passages, of course). That being the case, why is a water pump back plate even required? It sure looks like the water pump (and its gasket) should bolt right up to engine timing cover without any leaks.
The timing cover pictured
above is a Ford marine/industrial style front cover and will not need a waterpump backing plate since there are no deep cavities that a backing plate would cover up.
The standard front timing cover pictured on your engine
below does have the cavities (11 o'clock to 2 o'clock position) which get covered by the waterpump backing plate--do not leave the backing plate out with the standard cover as pictured below of your engine will have overheating problems:
