Old 06-14-2017, 02:56 AM
blykins blykins is offline
Originally Posted by Mark Brye View Post
Brent, I have seen several posts referencing the TKOs shifting smoother after being sent to you for mods. What do you do to the TKOs that help them shift smoother? Maybe I should weigh that as an option also....
I base that on the engine. If you spend a lot of time shifting over 6000 rpm, then I would recommend it. Otherwise, I don't think it would be cost effective, and I would only recommend using a good aftermarket shifter like a Steeda Tri-Ax.
When we do modify them, we correct the surface finish on the gear cones and synchronizer hubs, replace the shift finger, and then blueprint the thrust clearances.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
