Old 06-17-2017, 05:34 AM
SydneyChris SydneyChris is offline
Sparkie finishing off the wiring of the cruise, Motec PDM, keypad and immobiliser early next week, then to the tuners before getting the exhaust ceramic coated.
Looking into an intake plenum.. not dissimilar to a turkey pan set up to feed from the rear of the bonnet bulge to the airbox... wont be able to commence until I get it back.
Started it at the electricians on Friday for the first time with the high flow cats and side pipes fitted, has a lovely V8 rumble, although Im not confident it will meet the noise limits for a Wakefield, which is 100db.. would also make it a noisy 'cruiser' despite all of the attention to noise and heat insulation. Will see how it goes when it comes back as it was running in the back of a workshop and reverberating. Have seen solenoid controlled exhausts on US examples, with side pipes feeding into an under car system with a secondary muffler and rear discharge.. again, one to look into when it comes back..
Chris
FFR Coupe 65
LS3 motor, TR6060 box with Falcon ABS, 17" Halibrand wheels, 3.55:1 Ford Racing IRS and Willwood brake upgrade
