Old 06-25-2017, 07:05 PM
xb-60's Avatar
xb-60 xb-60 is offline
Thanks Tim. I have almost all required parts now, although there is still a short list of parts that are yet to be supplied by AP.
What's next? I need to fit the diff. and half shafts, then the fuel tank, and then I can start fitting the sheetmetal panels in the boot/trunk. Logically, after that, I should fit the panels under the hood and also start insulating.
Currently I'm doing what should be an easy one - modifying the alloy 'filter' panel so that it will fit in the hood scoop. It's supplied as a blank panel, so I will probably use the ERA FIA hole pattern rather than the larger holes that LP's CSX2259 uses.
Glen
