Old 07-02-2017, 01:12 PM
Texasdoc's Avatar
Texasdoc Texasdoc is offline
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
Sounds like you have a bad starter.
For the test, apply 12v to both terminals. Make sure you are getting at least 11v WHEN ACTIVATING the starter during the test. If your bench supply doesn't give enough power, you can see what you are getting. If you have both posts connected and are applying enough power, you have a bad starter. Where/when did you buy it? Can you return it?
Or, you can call JR Richmond at PowerMaster. He is great to work with. (630)293-5900.
