Old 07-05-2017, 01:47 AM
520SC's Avatar
520SC 520SC is offline
Cobra Make, Engine: 1966 Street Beasts Cobra 427 S/C, 502 cid
Thanks. Now that I have the oil pan removed I'll be able to check that the bottom of that shaft will mate with the oil pump no matter what I do from above. I'll repeatedly install/remove the distributor to verify that that the drive shaft can be seated properly. I'll repeatedly install/remove the oil pump priming tool to verify that that the drive shaft can be seated properly. After a successful "set of experiments", I'll be ready to transfer that oil pump to the new engine with confidence.
Just query on "Ford 460 oil pump drive shaft". The horror stories you'll find are mind boggling.
Todd
