  #30 (permalink)
Old 07-07-2017, 03:19 AM
deano59 deano59 is offline
Cobra Make, Engine: absolute pace chassis #50 L98 & 6 speed auto
Originally Posted by ICCARS View Post
I will need to rotate the steering rack on it's axis to have the steering input shaft for the rack turned up at approx. 45 degrees to clear the engine cam cover. All still coming together pretty good though and the chassis is almost nearing completion in the pre-assembly stage..
ive just done the same thing on a rack we fitted into a hq chassis and made it left hand drive as well ..to get the rack mounted and get bump steer and Ackerman's angle somewhat right the output shaft on the rack was pointing upwoulds I used a small 90 deg gearbox with a 1to 1 ratio off a conveyor belt system I mounted one end to the rack and the other to the shaft going up to the steering wheel problem solved ..cheers dean
a cobra is a passion anything else is just a car
i dont care what the question is .. The answer is more power!!!
