Old 07-09-2017, 04:34 AM
strictlypersonl strictlypersonl is offline
In CT, your biggest challenge will be getting the exhaust quiet enough (and you'll need heat shields over the side pipes). Emissions for a Composite Vehicle are pretty liberal. The only advantage of the 352 is a lower compression ratio (depends on the engine model) making it a little quieter.
Also note there's a minimum ground clearance, so you might have to crank up the spring adjustments.
