Old 07-09-2017, 06:11 PM
FUNFER2's Avatar
FUNFER2 FUNFER2 is offline
If I was ready, this is a great engine.
$13,000 (Offer less of course)
12.5:1 compression, but may be ok using aluminum heads and E-85 fuel on the street, but stretching it ?
489 CI 427 side oiler
Motor is complete and currently in my 66 Fairlane so you can hear it and drive it. The details are as follows:
Genesis block 4.280 bore
JE domed pistons 12.5 - 1
Scat 4.250 cast crank and H-beam rods
Edelbrock 60089 427 heads, SS valves mild gasket match & porting by Roush Performance
Comp Cams custom Hydraulic Roller & lifters .622 lift, duration 252I & 262E @ .050 112 LS
Nice choppy idle.
T&D street rockers
Short block built by Keith Craft
Less than 1000 easy street miles
Can be had with a couple different intake & carb combos. Currently has a Blue Thunder MR with BJ & BK carbs all new from Carls Ford Parts. I would rather keep the MR but could be talked into selling it as is. Also available with a Dove Tunnel Wedge or Edelbrock Victor w/Dominator carb flange etc.
Long Block $13000.00. Adder for intake and carb combo can be discussed.
Call to discuss other possibilities.
Regards,
Kevin
