Old 07-22-2017, 01:15 PM
Rawkkrawler's Avatar
Rawkkrawler Rawkkrawler is offline
Cobra Make, Engine: Everett Morrison
Originally Posted by cycleguy55 View Post
If you raise the engine you'll not only decrease clearance for your air cleaner, you'll change driveshaft angle and may need to modify your headers.
I had oil pan clearance issues as well, but solved them with a custom oil pan. Sump is about 80% of the length of the pan, with kickouts on both sides. Bottom of the pan sits 1/4" above bottom of frame rails. That's a much better solution, IMO.
100% agree! The C4 rear diff is fixed and the current angle is nearly flat now, so a little angle would help probably. But the sidepipes are a different issue, too close for comfort if I raise the engine a half inch or more, especially with rubber mounts.
I am going to just purchase a lower profile pan and be done with it. The Ford Racing pan is too low and is already listed here in the classifieds section, unfortunatley that's $600 that Summit won't refund on. Cobras aren't cheap!
Mike D
Tampa Fl
