Old 07-23-2017, 04:39 AM
cobrakiwi's Avatar
cobrakiwi cobrakiwi is offline
Cobra Make, Engine: Coombe, Shelby Block 496
Check the aluminum panels, the rear bulkhead and the inner rear splash panels around the fuel tank.
Also check the clutch fork, depending on what setup you have (external slave with fork) the fork can rattle against the main frame rail if not setup correctly.
