Thread: BDR cooling
Old 07-23-2017, 02:04 PM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by rlbarranco View Post
Guidance appreciated:
So, I'm looking for:
1) Intake aluminum shroud options
2) Post radiator shroud options that augments the current plastic shroud that came with the fan
3) Mount assembly needed to put the radiator at a slight angle
4) Suggestions on an oil cooler with thermostat that closes fully (some allow a small amount of oil to flow when shut which I want to avoid)
5) Suggestions on pusher fans with mounts (preferably not the center bar style - yes, I know pushers won't help much if at all).
Thanks a bunch for the assist!
Keep in mind that most people who own a BDR purchase them already built and drivable, and don't do anything more than routine maintenance and general repairs. Custom mods are not common. Unlike the FFR, there's not a lot of aftermarket support.
3. You'll have to custom fabricate that yourself.
4. You want some oil to flow through the cooler at all times. Otherwise, some of the oil will warm up, the thermostat will open up, and cold slug of oil will hit you bearings. And that's a bad thing.
5. Spal makes a couple of efficient pusher fans that might work for you, depending on what you have in mind.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
