Old 07-24-2017, 05:14 AM
Riverside racer Riverside racer is offline
Cobra Make, Engine: AC cox 2699 roadster Riverside FIA RSR2001
I experienced the same and fortunately had the air filter off with motor running (idling) in the garage and suddenly same symptoms occurred and I could see the fuel boiling and being dumped in the carb...Fix? Use a fuel with no ethanol and spacer and heatshield below the carb. making sure fuel line insulated. The Better fix is a regulator with a bypass and a return line to the cool fuel in the tank. Shell and Sunoco.
Ross
