Old 07-24-2017, 09:18 AM
BCJ BCJ is offline
Cobra Make, Engine: ERA 796 / ERAFIA 2043
Default ERA Pusher Fans - loose wire?
I have a 427 and when I switch the fans on (or when they automatically come on) the left one does not start. However, if I then just even slightly push the wiring into the motor or even touch it, the left fan will then start. From there it seems to fluctuate in speed.
Came out of nowhere and the car is somewhat new (#796) --- the only cause I could think of was some hose overspray getting in there when I recently washed the car.
I know nothing about wiring and the issue appears to be in the motor given the above info. Is there any quick fix or suggestion? I ask this question with full awareness that it's very novice. Thanks!
