Old 07-26-2017, 05:21 AM
ICCARS's Avatar
ICCARS ICCARS is offline
Cobra Make, Engine: AC Cobra - ICCARS 001, 4.2LTwin Turbo, AWD, 5 speed tiptronic under construction
Originally Posted by Treeve View Post
G'day Wil,
Unfortunately, you've misread what it says - it's a lot worse than that.
What is says is:
"ABS and/or EBS from the donor vehicle shall not be used."
This means you can't use the ABS from the donor vehicle, but you still have to have ABS - so you have to get ABS from somewhere else, then get it sorted for your vehicle.
Good luck finding a highway approved aftermarket ABS controller - or completing the full ADR testing as required by the comment at the start of the document.
Treeve
Thanks Treeve,
these people obviously have no idea of what they are doing in the slightest.. At least allowing the standard donor ABS to be installed would be a better start than trying to mix and match one to suit...
Lets hope their stupidity and narrow mindedness is not contagious..
Wil Escabache
ICCARS AC Cobra 001 (AWD) U/C
RF 098 GT40 Twin Turbo
ICCARS GT40 - U/C
www.iccars.net
