  #22 (permalink)
Old 07-27-2017, 10:58 AM
patrickt patrickt is offline
Originally Posted by RockBit View Post
Gary -you are the man. I redid the test today with the sensor case grounded. On the 10V converter the gauge indicated just a hair under 100C (local elevation is 430 feet). On the 12V supply the gauge showed 98C. All components seem to be working well.
Thanks for the help from everyone.
I would still use the voltage regulator, even if it's a nuisance to wire in. Remember, your alternator can kick your system voltage up to close to 14 volts, which starts to make a difference on the gauge.
