Old 07-27-2017, 05:47 PM
SydneyChris SydneyChris is offline
hi Gav.. yes mate.. installed these, these are the only lights on mine that are no LED as I couldnt find a suitable replacement in the 100mm dia. They are attached with M5 SS bolts into a threaded clip fitted thats to the bracket for the light.
Will grab a pic if you needed one, can unbolt these from the back to remove as required. I also added a 75mm x 3mm AL plate to the front of the bucket to increase the strength as the glass was only 3 mm or so thick at this point.
FFR Coupe 65
LS3 motor, TR6060 box with Falcon ABS, 17" Halibrand wheels, 3.55:1 Ford Racing IRS and Willwood brake upgrade
