Old 08-04-2017, 12:03 PM
1795's Avatar
1795 1795 is offline
Default Finally done, except for tuning
The fitting that I have been waiting for finally arrived. If you use a McLeod HTOB on your SPF FIA, the connector that comes with the HTOB is not the right size. I had to order one from Pegasus. You will need a 4AN to 10mm connector to splice the hard line on the car from the Clutch master cylinder to the HTOB. It is all in place and properly bled, tested the clutch and it works! Now all I have to do is work on fine tuning things.
Time to register for the race!
Jim
