Old 08-05-2017, 12:37 PM
cycleguy55's Avatar
Default Surge / Miss: Ignition or Carburation?
I've got the car running again, but get a surge / miss on light throttle cruise between 2,000 and 2,500 RPM. There's also more exhaust 'popping' or 'burble' on throttle-closed deceleration than before I replaced the ignition box and coil. There are no apparent issues at idle, when accelerating, or cruising < 2,000 RPM. I have not yet checked the timing but, other than replacing the magnetic pickup and distributor cap, the distributor was not touched.
Environment:
  1. MSD 8477 distributor (magnetic pickup swapped from old MSD 8577 distributor in process of getting car running)
  2. Summit Multi-Spark digital ignition control box p/n , mounted behind dash ( https://www.summitracing.com/parts/sum-850610 )
  3. Summit Epoxy coil ( https://www.summitracing.com/parts/sum-850500 )
Questions:
  1. Does this sound like an ignition or a fuel issue?
  2. Where do I start?
Brian
