Old 08-05-2017, 02:32 PM
PNJSNAK's Avatar
PNJSNAK PNJSNAK is offline
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
Loco
- call Joe T at A and C about shocks
- sometimes you adjust rings differently to get same height of body from side to side
Remember these are fiberglass bodies they are not perfect
- yes the springs will leave their home in the upper spring housing be careful
- not sure what the bolt is for mine have it also
Ask Joe T
- there should be rotational movement in the panard bar because the ends should
be brim joints
Last but not least
Salt shaker says remove the panard bar BUT you need to answer the question
are your four real links aluminum bars or are they adjustable bars
with brim joints at each end
If aluminum bars remove panard bar not necessary
If adjustable bars leave it
If it was installed properly it will work
Mine does
Jim
OhioCobraClub.com
