Old 08-07-2017, 12:11 PM
cycleguy55's Avatar
Originally Posted by Texasdoc View Post
Usually popping on decel is lean fuel.
And the surge / miss feels to me like a classic 'lean surge'. It was worse when I finally got the car running after 3+ weeks, then seemed to fade after being driven a bit. The biggest improvement was in the first 5-10 miles, then less after that.
I wonder whether the 3+ weeks of not running and the hot weather we had evaporated the fuel in the carb and left some deposits / varnish behind that are causing the problem.
I'm going to try running some carb or fuel system cleaner through it and see if that helps or resolves the problem. If not I'll be pulling the carb and tearing it apart.
Brian
