Old 08-07-2017, 08:27 PM
ICCARS's Avatar
ICCARS ICCARS is offline
Cobra Make, Engine: AC Cobra - ICCARS 001, 4.2LTwin Turbo, AWD, 5 speed tiptronic under construction
A bit more progress on the AWD Cobra today with the steering column positioned in place (nice and central to the seat position), the trans tunnel is starting to come together and I have made it wider to allow for the exhausts to run down either side of the trans inside the tunnel and shoot out through underneath the rear cradle as per the original path on the Audi's - should work a treat when the exhaust pipes are heat wrapped.
The front suspension arms are mocked up for relative position and I have designed the top arm mount plates so I can get them laser cut and then that will allow me to finalise the suspension in the mock up stage in any case. Look like the original struts are going to get the old heave-ho... and coil overs to replace them in the front/rear shock design set up.
Wil Escabache
ICCARS AC Cobra 001 (AWD) U/C
RF 098 GT40 Twin Turbo
ICCARS GT40 - U/C
www.iccars.net
