Old 08-11-2017, 04:31 AM
Bender Bender is offline
Cobra Make, Engine: G Force Cobra 347 stroker
Hi Chris. I saw a nice 8 butterfly cross ram tube intake set up to suit LS engine at a swap meet on the Gold Coast. New $1200. Thought of your car.
With the current manifold you have and with a bit of work and the turkey pan style airfilter.Connect a stainless 180 degree pipe to the throttle body and direct back over the engine into the turkey pan. Flat panel filter in pan, raised at the front and low a the back. Maybe you could cut a vent grill panel just under windscreen between the wipers. Similar to the MK 1 Ford Escort etc. Connect the back edge of the turkey pan to that. The early Supercar airboxes had like a door seal on the top edge of the sides of the pan used the bonnet as the top to seal out the hot under bonnet air.
Hope that all makes sense to you. lol
Bender
