  #62 (permalink)
Old 08-16-2017, 04:31 PM
FWB's Avatar
FWB FWB is offline
Originally Posted by ByronRACE View Post
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
Ran across this today in my amazon saved items list...thought it might be helpful.
Careful, the Dorman may look almost the same but its performance is far below the factory lincoln unit.
the blades are a different shape and there is one less blade.
i put a lincoln fan in another kellison with a 429 SCJ, which always ran hot previously, i used a flexolite programmable controller to set the on and off temps, and it worked flawlessly, had to make two clearance cuts in the shroud for hood hinge clearance and block off the opening between the rad and the inside of the body.
Fred B
