Old 08-22-2017, 05:30 PM
dcdoug's Avatar
dcdoug dcdoug is offline
My cam might work pretty well for you. You've probably seen my own rebuild thread at: Found this in my oil pan
The cam is a Holman Moody solid flat tappet "B" cam. Good condition with 6k miles on it. Only reason I'm changing it is because the rest of the rotating assembly is changing
Here are the specs:
Exhaust Duration = 242
Intake Duration = 242
Intake Center Line = 105
Exhaust Center Line = 107
Lobe Separation Angle = 106
Cam installed w/ key 2 deg advanced (I think)
Gross lift = .526
Overlap at .050 = 30 deg
Rocker ratio: 1.76
Cam card is here if you want to see it: Club Cobra - Powered by vBulletin
www.partskeeper.com
