  #23 (permalink)
Old 05-25-2002, 11:08 AM
niles niles is offline
Cobra Make, Engine: Hunter #28; 396 Cleveland stroker; more than 495 HP; TKO 5 speed
Default carb
slide;
Your getting good advise and its probably a float level adjust issue.
I just wanted to share a similiar problem that I had and the unusual solution. The car was a Porshe with 4 webbers that would bog coming out of a hard corner. everybody said float level; messed with in for months, no success. Finally gave in and made a appointment with "Cadrobbi" of S. Calif(super porche geru).
He appeared after waiting for 2 months to get an appointment; him in his white Dr's smock. Showed him the problem, returned to shop, he put a small level on the carbs and it showed a slight down bubble, he put a jack under the front of the car to level the carb, readjusted the floats, said "that will be $100 and its fixed." It was, never hesitated again.
gn
