Old 09-09-2017, 07:21 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Do some research on the markings that are on new tires when you purchase them. Light and heavy points on tires are marked with colored dots. Valve assembly on the rim is usually the heavy point, line it up with light section on tire. Interesting reading.....
The yellow dots should be aligned with the valve stem on wheels since this is the wheel's heavy balance point. This will help minimize the amount of weight needed to balance a tire and wheel assembly. So usually, whenever you see a yellow dot, match it up with the valve stem.
SPFWiringDiagrams@Comcast.net
