Thread: Radiator caps
Old 09-18-2017, 07:28 AM
EM-0785's Avatar
EM-0785 EM-0785 is offline
Senior CC Premier Member
Cobra Make, Engine: Everett-Morrison 514, Toploader 4 sp, Jag IRS
Steve,
Well you're probably well ahead on this, mentioning just in case. There are one way (non-recovery) and two way (recovery) caps, depending how your system is designed. The two way have the upper and lower rubber gasket/seal. Also, you likely know, but the pressure rating is important for the application. If too low a rating for example, it would release earlier than otherwise designed and perhaps a reason for losing fluid prior. Lots of cap difference/feature information on web searches if needed. Brent
