Old 09-20-2017, 09:15 AM
1795's Avatar
1795 1795 is offline
How close are the master cylinder and brake lines to the header and exhaust? You could be boiling the fluid in the lines and master cylinder and that could result in what you are seeing. If they are close you could add some heat reflective tape to protect them.
Would not hurt to bleed the brakes again as well, it is amazing how long after you bled them that you can come up with air bubbles again.
