Old 09-21-2017, 01:35 PM
EM-0785's Avatar
EM-0785 EM-0785 is offline
Senior CC Premier Member
Cobra Make, Engine: Everett-Morrison 514, Toploader 4 sp, Jag IRS
Originally Posted by cycleguy55 View Post
FWIW, I was having no end of challenges bleeding my brakes (same as you - 4 piston Wilwood in front and GM brakes rear).
I finally gave in and put speed bleeders in all my calipers. Problem solved. Highly recommended.
Cycleguy55,
Question on the speed bleeders. I had bought multiple bleeder sets for my rear Girlings. Non check valve version for use in reverse bleeding/flushing if/when needed and check valve speed bleeders left in afterward for regular maintenance.
On my new front Wilwoods I didn't install bleeders there (yet, wanted to) with concerns of others on the web having issues damaging the threads/seal with speed bleeders on their Wilwoods.
I don't believe Wilwood sells them (maybe?), but do you have a brand you like or any specific advice/cautions in that regard? Maybe the others were just not careful to really ensure the right bleeder dimensions (easy to figure)?
Those like myself, and perhaps the OP, could benefit from any thoughts there. Thanks, Brent
