Old 09-21-2017, 02:29 PM
Akimbeau Akimbeau is offline
Cobra Make, Engine: ERA 289 FIA 351Windsor
Originally Posted by joyridin' View Post
From what you described in your original post, it sure seems as though the rear brakes are out of adjustment. The GM calipers use a ratchet mchanism and sometimes, you can just be on the edge of it clicking, which will move the pad closer to the rotor and your pedal will be high. I have literally done a hundred brake jobs with these style calipers and probably half of them end up with the situation you describe. This is of course assuming there is no air in the system .
I'm following a GM guide for adjusting the e brake lever. What I end up with is the lever will have about 1/4" gap between the stop and when the e brake is locked up. The pads end up tight to the rotor when the e brake lever is on the stop.
