Old 09-22-2017, 09:50 AM
Akimbeau Akimbeau is offline
Cobra Make, Engine: ERA 289 FIA 351Windsor
So I tried the adjustment procedure mentioned by Joyridin' with no change in symptoms. I also tried shimming the outer brake pad to compress the piston further into the caliper body, no change. Should I consider a 10lb valve like is used on drum brakes?
Kim
