Old 09-22-2017, 10:31 AM
undy's Avatar
undy undy is offline
Originally Posted by MOTORHEAD View Post
Just ordered the Taurus fan today, but the relay kit mentioned earlier in this thread seems to be unavailable. I need a kit with a 50 amp relay that will switch the b+ from the "low" speed wire to the "hi" speed wire, this may require 2 relays and a 3 position sw, but not the same as a 2 fan kit. I'm guessing that when power is applied to one speed, it is removed from the other. Or not ? Plus a temp sensor sw would be nice. Been looking thru Summit and amazon till my eyes cross ! just can't be sure which kit will work. Lots of dual fan kits, no dual SPEED kits. Any help appreciated !
Ted
I just talked to Mr. Hollister and his setup is most definitely available for the 2 speed Taurus fan. It comes with the relay pack, both temperature sending units, instructions and all needed wiring. This is the same setup I installed in mine around 10 years ago. Here's the link...
https://www.hollisterroad.com/prodde...prod=TM8BA1820
Too many toys?? never!
