Old 09-22-2017, 06:48 PM
EM-0785's Avatar
EM-0785 EM-0785 is offline
Senior CC Premier Member
Cobra Make, Engine: Everett-Morrison 514, Toploader 4 sp, Jag IRS
Originally Posted by cycleguy55 View Post
The thread size is 1/4" x 28 TPI. I know Wilwood shows bleeders as 1/8"NPT, but that's a bushing with an internal size of 1/4" x 28 TPI. You'll need a pair for each front caliper - installed as replacements for the upper bleed screws. You can leave the lower bleed screws in place.
If memory serves me correctly, my speed bleeders are Russell. I had no problem stripping or damaging the threads in the calipers, but I was careful to ensure the threads were engaged properly before putting a wrench on them.
Brian, thanks much!
Kim (Akimbeau), best of luck, sounds like you're narrowing it down with some very good advice from others.
Brent
