Old 09-26-2017, 09:44 AM
rodneym's Avatar
rodneym rodneym is offline
Full Blown Member
Premier Contributor
E5USMC,
In my CSX (with same KMP diff as yours except you have the new billet cover ) I had a similar issue. During the install shakedowns, everything was great. Then on my first "long" drive (1 hr home) I found a big mess under the rear - gear oil everywhere! I check the level and it was about .5" below the fill plug, so it was initially overfilled, got to a real operating temp and puked, and found its new level. It initially had a breather tube pointed down at about the same height as the diff, which I believe may have acted as a siphon. I installed a catch can inside the trunk like on my KMP and it's been dry since.
That drip from the fill plug was definitely a sign of it being overfilled (or the plug not nearly tight enough) but should have held anyways like patrickt said.
With the new fill level and can, you'll be fine.
rodneym
