Old 10-07-2017, 11:01 AM
Akimbeau Akimbeau is offline
Cobra Make, Engine: ERA 289 FIA 351Windsor
Default Jag rear end camber adjustment advice needed.
I'm going to take some excess neg camber out of my jag rear end and wanted to know the best procedure before I break into it. I'm not certain how much has to come off(shocks sway bar etc) to get the half shafts loose to insert the shims. Do I just loosen the 4 half shaft bolts and the half shaft will come away from the rotor? There doesn't appear to be enough room on the backside of the rotors for the 4 bolts to be drawn back far enough for the half shaft to fall away, I thought I would ask the group for advice from someone thats been there before me. Thanks!
Kim
