Old 10-09-2017, 10:39 AM
MKS427's Avatar
MKS427 MKS427 is offline
Cobra Make, Engine: FFR MkIV 427
I have heard the Taurus fan works well and does pull about 40 amp in high.
If you are having low speed issues, a proper shroud is the best place to start to ensure you are using 100% of the radiator.
When selecting a fan, DO NOT accept the listed CFM as real world. You have to do a little internet research. Go to the fan manufactures website and look up the specs for the specific model number. You want to ignore any CFM ratings below 0.7". Generally, low amperage fans, below 20 amps roughly, will not pull or push air above 0.7".
Mark
