Old 10-13-2017, 09:45 AM
patrickt patrickt is offline
Dan, it's only 100 lbs. -- just build a quick block and tackle hoist with 2 x 4 wood pieces and roller casters on the bottom. Use bolts to connect the pieces so you can easily disassemble them when you're done. With a weight that is only a hundred pounds, a 4:1 block and tackle will make it easy to lift up and the roller casters will let you roll it around to wherever you want it.
