Old 10-14-2017, 09:50 AM
Dan Case's Avatar
Dan Case Dan Case is offline
Original Shelby Owner
The 4HU was used on the later build Aces, 260/289/427 Cobras and AC "Frua" 428 cars as well as the "Paramount" chassis and the electric AC chassis. It handled from 150 HP to godafful torque on the 427 S/C cars!
Early Cobra upper differential hangers, bolted onto sides of the differential that contained a steel and rubber vibration isolation core, originally had cast iron bodies. That first version tended to break in any kind of competition. They were replaced with similar looking assemblies with high strength steel bodies pretty early in Cobra production. Apparently, late in the 427 Cobra era another design revision was made available as an upgrade for competition use.
Salisbury O.E. differential output shafts were somewhat soft. 289 powered cars that were drag raced or 427 powered cars with wide rear tires tended to twist them or in extreme cases break them after sufficient twisting. Custom replacement output shafts were a common solution for race cars. I bought a custom American made pair for a friend’s 427 Cobra circa 1985 to replace the deformed originals. Legend says that Ted Halibrand's company made extreme duty replacement for racing output shafts for differentials and custom rear hubs (axles in rear uprights) for Shelby American.
Dan Case
