Old 10-14-2017, 10:30 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Nothing against Jim Inglese, he has been around a LONG time.
But something is not right with this setup.
The mixture screws should only be about 3/4 to 1 turn out from seated, if the idle circuit calibration is correct.
Your cam is not overly wild, so it should idle quite nicely, once set correctly.
Have you synched the carbs with a synchrometer?
How far open are all the butterflies to get the engine to idle?
