Old 10-16-2017, 11:45 AM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by RockBit View Post
My tank is hard to fill. I have to trickle the gas in or the nozzle shuts off. A couple of times I have had a geyser of gas cascade down the fender. It is hard to know when the tank is full.
I unexpectedly had that same geyser occurrence once myself. I'm not clear exactly what caused it but I'm suspecting I didn't have the nozzle far enough down the filler pipe and fuel flowed into the vent opening near the top of the fill pipe, filling it and causing pressure to build in the tank and belch back out the main filler.
Maybe Bob can venture some thoughts on this subject.
Since then I shove the nozzle as far down fill pipe as it will go but I still meter fuel in slowly to avoid a repeat.
I feel pretty confident of knowing when my gage is working. Just saw back and forth on the steering wheel a couple of times and the needle will slowly rise and fall - or fall and rise. If not, something is wrong.
ERA 782 Running
