Old 10-16-2017, 01:44 PM
Cobra #3170 Cobra #3170 is offline
Originally Posted by Dan Case View Post
Early Cobra upper differential hangers, bolted onto sides of the differential that contained a steel and rubber vibration isolation core, originally had cast iron bodies. That first version tended to break in any kind of competition. They were replaced with similar looking assemblies with high strength steel bodies pretty early in Cobra production. Apparently, late in the 427 Cobra era another design revision was made available as an upgrade for competition use.
Salisbury O.E. differential output shafts were somewhat soft. 289 powered cars that were drag raced or 427 powered cars with wide rear tires tended to twist them or in extreme cases break them after sufficient twisting. Custom replacement output shafts were a common solution for race cars. I bought a custom American made pair for a friend’s 427 Cobra circa 1985 to replace the deformed originals. Legend says that Ted Halibrand's company made extreme duty replacement for racing output shafts for differentials and custom rear hubs (axles in rear uprights) for Shelby American.
Those original diffs. had 10 spline stub shafts that were quite soft as you stated. I broke 2 before switching to 19 spline Jag units which also broke occasionally. I have the 30 spline Kirkham stubs now and they are holding up perfectly. I still have my original 10 spline diff but have not used it since
1981.
