Thread: Bump Steer
Old 10-17-2017, 06:42 AM
Luce Luce is offline
Cobra Make, Engine: Lone Star with IRS, 427W with megasquirt, T56 magnum
The caster affects the needed elevation of the rack. If you're running more positive caster than the stock M2 alignment, you may need to raise the rack. With a little geometry you can figure out how much. I think you could easily elongate the 2 rack mounting holes and fix it that way, or reduce the caster. The positive caster gives more restorative force to center the wheel at speed, which isn't a bad thing in this short wheel based car. I think I'm only running 2 deg and have no noticeable bump steer.
