Old 10-18-2017, 11:42 AM
RockBit's Avatar
RockBit RockBit is offline
Cobra Make, Engine: ERA #812 427/482 FE
Originally Posted by AC Ventura View Post
Thanks Chris. Do you know if these are still available? I cant see them online, only the Anchor 2222 and 2223 listed by Summit, although I'm guessing these must be the same ??
The Anchor units look the same as mine. You can also search for Ford part numbers C3AZ-6038A,B. Those will work also.
ERA recommends drilling a hole though the rubber on the left mount and putting a 7/16 x 2 inch bolt through the mount with a stover nut on it for high Hp/TQ applications. This will keep the mount from pulling away from the rubber when the power is applied. If you search for ERA manual supplements (Google) this modification is shown.
Chris
