Old 10-20-2017, 01:35 PM
RodKnock's Avatar
RodKnock RodKnock is offline
You know there's almost a full inch difference in the diameter of the Yoko Avids and the Avon tires, both 295 and 275. If you want your car to look the same when it's just sittin' there, you're going to have to have your ride height adjusted. And if you're going to do that, then you'll have to have your corner weights checked as well.
The front tires will be about 0.6" more diameter and the rear will be about 1" less diameter. I'll let the shop sort it out.
I didn't think adjusting the height is a big deal. But thank you for the info.
I was hoping someone would chime and say, "Ya, those 275/55's in the rear have less sidewall flex than the 295/50's and what a handling difference." But I guess everyone here opts for "form over function."
