Thread: New coupe
Old 10-22-2017, 02:25 PM
bobcowan's Avatar
bobcowan bobcowan is offline
That low speed bucking can be caused by a lot of things. Could be something simple like incorrect ignition timing. Or a rotating assembly that's too light. You can get that from any engine, depending on how it's built, and the drive line behind it.
The Coyote is a huge engine. It's a lot wider than the Windsor engines. Getting it to fit in a car not specifically designed for it can sometime be a challenge. But it is a great engine. If the car you purchased is set up for the Coyote, consider installing it. It's a great engine for such a small displacement.
If the car is not set up for the Coyote, I wouldn't try to adapt it. It's a lot more work than you might think it is. Lots of cutting and fabrication involved. If you can easily do that kind of work, great. If not.......
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
