Old 10-29-2017, 02:16 PM
patrickt patrickt is offline
Originally Posted by jetblue69 View Post
Numbers?
I went with the outboard braked rear, so it's not like I can trot down to the garage and check but, as I remember it, there are four pre-XJ40 widths of the Jaguar IRS floating around out there. Plus, you can also run across different coil-over shock installations and different brake options and locations.
So, with that said, and with no guaranties as to accuracy, measured from wheel flange to wheel flange, here are the numbers:
XJ6/XJ12 1549.4mm/61 inches
E‐Type 1320.8mm/52 inches
Mk10 & 420G 1536.7mm/60.5 inches
S‐Type & 420 1397mm/55 inches
